Fstorm mix not rendering
  • Fstorm mix not rendering
    Hi
    Recently I wanted to combine fstorm noise with a random fstorm bitmap in a fstorm mix with a random blending mode and use it in a bump slot. RT restarts but no change is made. When i render the map combined and use it as fstorm bitmap again it renders correctly. Could it be that fstorm mix is bugged?
    thanks
    I restarted max and now it works. All Good!
