Hello Karba !
Working with Fstorm and Particle Flow noticed a bug that has hit the my work, ask to see and correct it please.
I attached you the video of this problem. Briefly about the problem: Not updated Particle Flow with animated objects in Production Render.
If you turn off - Fast Shape Evalution it starts to work! But this causes freezes and long updates Particle Flow (this check mark is always included so as not to lag viewport regardless of the render engine)
In video can be seen that the RT it makes perfect. Fix Please... Even I had to postpone the rendering of the project. = (
However, any manipulation of the material or Particle Flow cause large freezes (if you turn off the check mark) - For example Video 2. (https://vimeo.com/190817291)
Thank You !
Thank You !
