If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Hi Karba. Could you add a map to use vector files (ai, svg, dxf, ...) as texture/map, like the Max standard vector map, and make it compatible with FStormDisplacement?
Thanks
Oh too bad.
Maybe an acceptable way: the map could convert the vector file to a bitmap according settable resolution, with "adaptative" option which defines the optimal resolution according to the render resolution / object proximity (from camera).
