RT window works but production rendering does not
  • RT window works but production rendering does not
    I think I had this issue a few years ago as well but I can't remember how I fixed it back then. When I open a scene and run the RT window, it renders fine. But when I hit production render to render an animation, it produces a black screen immediately; it does not load assets. The system has multiple GPUs installed and I can experience some crashes from one card in the system. Even when turning off all but one card it does not change anything. The render log does not say anything. I have the latest Fstorm version installed.
    How can I fix this?
    Thanks!
    -Joep
    Hi. Do you have a valid license?
      Not at the moment. But block production render if no license is not checked. Also, I'm able to render out production renders on my other PC. So it is definitely an error with that computer.
        Any errors in render log?
          no nothing. I also tried to render on just one gpu (and different ones) but that gives me the same result. Again, RT mode works fine.
