FStormRender for 3ds Max v1.3.3i (updated 16/08/2019)
  • FStormRender for 3ds Max v1.3.3i (updated 16/08/2019)
    • geometry memory optimization (30%-50% less memory use)
    • focus picker ignores invisible (zero opacity) objects
    • bitmap random tiling
    • corona color correction texture conversion
    • triplanar independed axis rotation
    • incorrect production render alpha
    • broken motion blur and displacement bump mapping
    • right click cancel fstorm ligth creation crash
    • network rendering crash
    • broken geopattern normals
    • broken geopattern uvw coordinates
    • incorrect object colors with motion blur
    • incorrect reflections/refractions visibility of material Id channel
    • incorrect network rendering
    • broken focus picker in case of some gpu disabled
    • incorrect motion blur geometry
    • incorrect render mask with multiple reflections/refractions
    • diffuse material affects multimatte/material Id channel
    • fstorm light sources affect material Id channel
    • broken support of old gpus models
    • scene conversion bugs
    • incorrect triplanar bump shading
    • incorrect environment direct lighting sampling
    This build requires 3ds Max version 2014 - 2019, GPU with CUDA support and compute model 2.0 or higher. https://developer.nvidia.com/cuda-gpus
    Network slave requires full license at the moment. There will be a special network license in the future.
    Render slave software is in RenderSlave folder and has to be run on render node PC.
    This build has a speed drop about 3-5% because of geometry memory optimization. It will be fixed in the future.
    Version is updated to 1.3.3a
    Fixes:
      Version is updated to 1.3.3b
      Fixes:
        Version is updated to 1.3.3c
        Fixes:
          Version is updated to 1.3.3d
          Fixes:
            Version is updated to 1.3.3e
            Fixes:
              Thanks for your hard working
                Version is updated to 1.3.3f
                  Version is updated to 1.3.3g
                    Version is updated to 1.3.3h
                      Version is updated to 1.3.3i
