FStormRender for 3ds Max v1.3.4g (updated 05/11/2019)
  • Karba
    started a topic FStormRender for 3ds Max v1.3.4g (updated 05/11/2019)
    • portals + environment direct lighting optimization
    • fstorm bitmap texture transform input (from another texture)
    • fstorm random color input slot
    • right click pixel info
    • network license support
    • distance texture
    • color correction settings input
    • improved sampling of long lights
    • glossy preserve clamp option
    Bug fixes:
    • broken IES lighting
    • slow instances processing
    • slow direct lighting processing
    • portals sampling artifacts
    • incorrect gpu memory display
    • incorrect rounded edges + motion blur
    • no prodution render in case of offline mode
    • distance+bitmap textures crash
    • sun + exclude gpu crash
    • distance texture offset doesn't work
    • distance texture geometry crash
    This build requires 3ds Max version 2014 - 2019, GPU with CUDA support and compute model 2.0 or higher. https://developer.nvidia.com/cuda-gpus
    This build may change scene environment lighting significantly. Don’t use for current projects.
  • Karba
    replied
    Version is updated to 1.3.4g
    Bug fixes:
  • Karba
    replied
    Version is updated to 1.3.4f
    Bug fixes:
  • lhenix
    replied
    you have to increase motion blur samples.
    yes, you are right, Thx!
    but I foud another issue:
    Set glare option of size & power value to 1 in black backgroud, will be get some not good result, like this pic,color breakage........
  • Karba
    replied
    Originally posted by lhenix View Post
    why?
  • lhenix
    replied
    why?
  • Karba
    replied
    Version is updated to 1.3.4e
    Bug fixes:
  • Karba
    replied
    Version is updated to 1.3.4d
    • distance texture
    Bug fixes:
  • Karba
    replied
    Version is updated to 1.3.4b
    Bug fixes:
  • Karba
    replied
    Version is updated to 1.3.4a
    Bug fixes:
  • manish_mv
    replied
    Please check as ram player comparison attached that there is a drastic decrease in les light illumination. the bottom one shows render from 1.3.4 and upper is with previous one 1.3.3I.
    however i am unable to see any change in environment direct lighting which is exactly the same. The environment lighting in scene coming from HDR.
    With deepest core of my heart! this rendering engine is really really amazing and super fast far ahead than vray and corona.
    You are doing really great work keep it up.
