FStormRender for 3ds Max v1.5.2j
  • FStormRender for 3ds Max v1.5.2j
    • Ray tracing rework
    • Faster rendering (depends on a scene)
    • Lower GPU memory use (depends on a scene)
    • Scattering instances along shape objects (FStormScatter)
    • Camera motion blur option
    • Bitmap texture animation offset and speed
    • Geometry reload button works with active pause button
    • Optimized colorful SSS and atmosphere
    • FStorm camera objects exclude/include
    • FStorm camera dof object focal distance
    • Itoo RailClone instancing support
    • Build-in mix texture to FStorm falloff, noise, dirt and front-back
    • 3ds max Instancing API support
    • Adjusted tonemapping contrast
    • different tonemapping types
    • dedicated emission material
    • options for quick fur, scatter, pattern, volumetric disable
    • texture switch
    Bug fixes:
    • Broken geometry on flat surfaces
    • Geometry compilation crash
    • Broken FStormScatter UVW mapping
    • Slow scatter generation while RT rendering
    • Slow rendering with zero size objects
    • Backing texture seams
    • Incorrect RailClone geometry fetching
    • Some scatter parameters are not updated in animation
    • Motion blur crash
    • Invisible to camera makes object completely invisible
    • Incorrect FStormScatter nodes pins positions
    • FStormScatter viewport update lags
    • Incorrect rounded edges look on scaled instanced geometry
    • GPU errors on incorrect FStormScatter geometry
    This build requires 3ds Max version 2016 - 2023, GPU with CUDA support and compute model 2.0 or higher. https://developer.nvidia.com/cuda-gpus
    Version is updated to 1.5.2a
    Bug fixes:
    • Incorrect instancing geometry rendering.
      Version is updated to 1.5.2b
      fixed some bugs of new Ray tracing.
        Version is updated to 1.5.2.c
        Bug fixes:
          Version is updated to 1.5.2.d
          Bug fixes:
            Version is updated to 1.5.2.e
            Bug fixes:
              Version is updated to 1.5.2f
              Bug fixes:
              • Motion blur crash
                Version is updated to 1.5.2g
                Bug fixes:
                  Version is updated to 1.5.2h
                  Bug fixes:
                    Version is updated to 1.5.2i
                    Some small bug fixes.
                      Version is updated to 1.5.2j
                      • texture switch
                      Bug fixes:
