FStormRender for 3ds Max v1.5.3n
  • FStormRender for 3ds Max v1.5.3n
    • Grid type displacement (supports procedural textures)
    • 3ds max 2024 support
    • Light material support in Light Lister
    • FStorm Scatter + grid displacement support
    • Scene Lister (Light Lister + other scene resources)
    • Use of uvw channel as vertex velocity
    • Increased tonemapping precision on dark areas
    • Proper FStorm Scatter copying
    • Scatter support for material projections
    • Material projections motion blur
    • Include/exclude option for scattered objects
    Bug fixes:
    • geometry compilation crash
    • broken FStormRandomColor texture
    • incorrect IES lighting orientation (may affect current scene lighting)
    • broken color picker in FStormGradient texture
    • broken bitmap random tiling bump
    • scene converter crash
    • gpu crash
    • broken displacement triplanar mapping
    • slow/incorrect grid displacement render on broken geometry
    • slow/incorrect motion blur render on broken geometry
    • Broken color bitmap compression
    • Shading artifacts on remote surfaces from scene origin
    • Incorrect render element noise measure
    • Incorrect Scene Lister UI scaling
    • Displacement grid doesn't work with instance geometry
    This build requires 3ds Max version 2014 - 2024, GPU with CUDA support and compute model 2.0 or higher. https://developer.nvidia.com/cuda-gpus
    This version may affect scene lighting. Do not update on major projects.
    version is updated to 1.5.3b
    Bug fixes:
      version is updated to 1.5.3c
      Bug fixes:
        version is updated to 1.5.3d
        Bug fixes:
        • gpu crash
          version is updated to 1.5.3e
          Bug fixes:
            version is updated to 1.5.3g
            some bugs fixing
              version is updated to 1.5.3h
              Bug fixes:
                Не пойму это баг или фича такая, после нового обновления 1.5.3h текстуры после FstormColorCorrection клампятся и соответственно если туда загружена hdr - солнце перестает светить.
                Было бы здорово оставить возможность клампить текстуры например при помощи галочки, а для hdr соответственно её отключять когда необходимо.
                  Version is updated to 1.5.3I. some small bugs are fixed.
                    version is updated to 1.5.3j
                    Bug fixes:
                      Version is updated to 1.5.3k, small bug fixes.
                      • #12
                        Version is updated to 1.5.3m
                        Bug fixes:
                        • #13
                          Version is updated to 1.5.3n
                          Bug fixes:
