FStormRender for 3ds Max v2.0.0W
  • FStormRender for 3ds Max v2.0.0W
    • Displacement as material.
    • Intel Open Image Denoiser.
    • PBR compatible material.
    • 3ds max 2027 support.
    • Camera chromatic aberration.
    • Display of FStorm material in viewport.
    • Speed up bitmap compression.
    • FStorm Scatter multiple objects list.
    • FStorm Scatter point cloud preview.
    • Material projection texture preview option.
    • FStorm scatter animation offset.
    • FStorm instancer (instances editing on sub object level).
    • FStorm camera film size.
    • Material picker from RT buffer.
    • Object picker from RT buffer.
    • ZDepth render element AA option.
    • FStorm Gradient texture clamp option.
    • Gradient texture tiling.
    • Distance texture crash.
    • Incorrect MixMaterial update.
    • Incomplete FStorm Scatter preview updated.
    • Broken region rendering in production mode.
    • Incorrect emission from motion blurred objects.
    • Broken FStorm Scatter manual preview update.
    • Viewport ignores FStorm material opacity value.
    This build requires 3ds Max version 2016 - 2025, GPU with CUDA support and compute model 2.0 or higher. https://developer.nvidia.com/cuda-gpus
    Version is updated to 2.0.0B
    • Geometry compilation crash.
    • Intel denoiser crash on early 3ds max versions.
    • Intel denoiser + light mix crash.
      Version is updated to 2.0.0C
      • Improved PBR glossy reflections.
      • Update scene button refreshes render resolution.
      • Interactive rendering crash.
        Version is updated to 2.0.0D
        • RT crash during scene saving.
        • Incorrect PBR material shading.
        • Intel denoiser hang.
          Version is updated to 2.0.0E
          • Poor bump accuracy of PBR material.
          • Broken parallax bump of PBR material.
            Version is updated to 2.0.0F
            • Intel denoiser quality option.
            • Broken diffuse bump.
            • Slow bitmap reload on heavy scenes.
              Version is updated to 2.0.0G
              • Improved Inter denoiser quality
              • FStorm Scatter UI crash.
              • GPU crash while emission geometry editing.
                Version is updated to 2.0.0H
                • Speed up FStorm Scatter point cloud preview.
                • FStorm Scatter crash.
                • Broken PRB refraction alpha.
                  Version is updated to 2.0.0I
                  • Less intel denoiser CPU load.
                  • FStorm scatter slow interactivity.
                  • FStorm scatter crash while rendering via render manager
                    Version is updated to 2.0.0J
                    • New FStorm installer/uninstaller.
                    • Arnold and some other plugins loading errors.
                    • Scene compilation hang with displacement + emission material.
                    • RT tonemapping changes restart rendering.
                    • FStorm Scatter node copying resets objects list.
                      Version is updated to 2.0.0M
                      • FStorm Instancer copying crash.
                      • Incorrect geometry update in some cases.
                      • Broken PBR refraction glossy mapping.
                        Version is updated to 2.0.0N
                        • FStorm Instancer editing crash.
                        • Network rendering + Intel denoiser hang.
                          Version is updated to 2.0.0P
                          • Broken Mix material on option.
                          • Material preview rendering GPU errors.
                            Version is updated to 2.0.0Q
                            • Lighting artifacts on low poly objects.
                            • #15
                              Version is updated to 2.0.0S
