Create FStorm Camera from View
  • Iskánder ivp87
    replied
    Originally posted by Sylk View Post
    In this case it concerns your keyboard drivers i think. What's your keyboard?
    its an AOpen, don't know the exact model
  • Iskánder ivp87
    replied
    did I up load an incorrect file?
    macroScript Macro15
    category:"DragAndDrop"
    toolTip:"Creating FStormCamera From View"
    if it's not this tell me, I test it right now and it worked fine, all the options, to create a camera from view you have to be in a perspective view, not in an orthographic one
  • Sylk
    replied
    Originally posted by Iskánder ivp87 View Post
    finally!!!, maybe now is not that relevant, don't know why the site didn't let me upload it
    Doesn't work. Not proper code and wrong script name.
    It creates a cam but not from view.
  • Sylk
    replied
  • Iskánder ivp87
    replied
    I assume your keyboard use a software to configure keys and detect opened app. If you can add custom apps, add 3dsmax.exe. Otherwise need more details of what you use.
    no, it let me configure the keys but no idea in how detect which program is opened, what it actually do is to give each keyboard a specific id and assign the functions of the program that you want... well any program but 3ds!
  • Sylk
    replied
    hey Silk, I have a second keyboard for After Effects, and have some keys left without assigned functions, I have tried to assign 3ds functions to it but it doesn't work, what could be missing there?
    just to test I have assigned commands for Photoshop, AIMP and even MS Outlook without trouble, but with 3ds max I don't know what is happening
  • Iskánder ivp87
    replied
    No, Standard cam is also useful with fstorm. You can't force to change renderer to use it. And you suggest to assign shortcut ctrl+c to script, so careful.
    ha I see, yes it's a valid point, but I never suggested him to do it, he asked me #21 and I told him how, but I am keeping cont + c for standard camera myself
  • Sylk
    replied
  • Iskánder ivp87
    replied
    anyway it should be fairly easy to do, just do a render check first and in case you are NOT using fstorm as defautl render, create a standard camera, in case you are, then run the script
  • Iskánder ivp87
    replied
    Not yet tested but, are you sure you can still create standard cam from view with this script?
    yes, I only didn't assign it cont+c to run it, I run it from a button or by pressing cont+f... I still reserve cont+c to create a standard camera
  • Sylk
    replied
  • mitviz
    replied
    well first you have to go to customize and assign the "control + c" shortcut to the script, and then that's it... it will tell you that the shortcut is already in use, you can do it any way and then create Fstorm cameras by default, or you can assign it another shortcut
    aha, thanks! very useful
  • Iskánder ivp87
    replied
    Originally posted by mitviz View Post
    thanks! very handy, just control +C and that's it?
  • mitviz
    replied
    I already up loaded it, see the #17 comment
  • Iskánder ivp87
    replied
