Benchmark Scene 2 (version 0.3.6a or higher is required)
  • #76
    Fstorm version: 0.3.7a
    Cpu 17 4790k 32gb ram
    Gpu: Gigabyte GeForce GTX 1060 Windforce OC 6GB
    Rendertimes
    Stock OC Boost @ 1929Mhz 15:09
    + 221Mhz @ 2150Mhz 14:08
    • Miguel1900
      Miguel1900 commented
      Great numbers Annkos. Did you confirmed stable OC at those frequencies, passing Unigine Heaving, for example? Or is it an OC only used for Fstorm, even if not stable at Unigine? Thanks!
    • annkos
      annkos commented
      Thanks Miguel, i only used it for f-storm but i ll make the benchmark and i ll let you know.
  • #77
    Fstorm version: 0.3.8
    CPU: 6700K @ 4.4 GHz with 32GB RAM
    GPU: MSI GTX 1080 GAMING X 8GB OC +125 MHz = 2056 MHz + MSI GTX680 Stock
    Rendertimes:
    GTX 1080: 09:33
    GTX 1080 + GTX 680: 08:53
    • #78
      Gainward Phoenix GTX1070 @ 2101Mhz / 4399Mhz
      Rendertime: 10:01
      Fstorm 0.3.8 / Driver 375.76
      Rendertime: 09:57
      Fstorm 0.3.7a / Driver 375.57
      Rendertime: 10:00
      Fstorm 0.3.7 / Driver 375.57
      Rendertime: 10:13
      Fstorm 0.3.6a / Driver 375.57
    • #79
      CPU: 4790K @ 4.7GHz, 32GB or RAM
      GPU: 2 x EVGA GeForce GTX 1080 FTW ACX 3.0 with stock settings (waiting for thermal pads), driver version: 375.70
      Render time: 5:15
      • #80
        GTX 1060 SC +125 @2126 v0.3.8: 13:52
        Screen conected to motherboard.
        EVGA GTX 1060 SC 6GB GDDR5 @ 2151MHz || i7 3770 @ 3,7GHz || G.Skill Ripjaws X 16GB @ 1600mhz
        • #81
          Render version: 0.3.8a
          Config: 1 X ZOTAC GTX 970 (Dual fan)
          Render time: 17:23
          • #82
            Fstorm version: 0.3.8a
            CPU: i7 5820k @3.3Ghz 32gb ram
            GPU: 2 x NVIDIA GeForce GTX 1080 8GB @ Stock: 1658MHz, Boost: 1797MHz
            DriverVersion: 375.70, SLI = OFF
            Rendertime: 5:28
            • m17a4y
              m17a4y commented
              You should never use SLI for rendering. Also, may I ask which manufacturer's GTX 1080s you have?
          • #83
            Lil board update would be welcome. Thanks
            2x Gainward GTX 570 Phantom
            FS v0.38a
            Drivers 375.63
            Time: 35:49
            • #84
              Wow, wow, wow! Really impressive!
              New try with the v1.0.1a => 25:45 !!
              -40% Just AWESOME!
              • #85
                New update with new GPU configuration:
                1X GTX 1070 MSI GAMING X
                1X GTX 1070 KF2A EX
                Fstorm V1.0.1a
                Driver: 376.1
                Time: 5:28
                Update with a light oc (Same frequency on both cards) : 5:17
                • #86
                  i7 6700K
                  32 GB DDR4
                  Nvidia Driver 376.19
                  FStorm 1.0.1
                  GTX Titan X (Maxwell) stock speed - 13:35
                  Am I doing something wrong here? Should it take this long for a Titan X?
                  • #87
                    hi all
                    i'm new on FS
                    for the test:
                    3Dmax 2015
                    Fstorm 1.01c
                    Laptop: Asus Rog GL502VM - GTX1060 6GB
                    time: 17:26
                    temp: 68°
                    • #88
                      I'm new here as well. I didn't see results with GTX 980 (non Ti). So here are mine:
                      FStorm 1.0.1c
                      CPU: i7 4930K
                      RAM: 32 GB RAM
                      GPU: 1 x Gigabyte GTX 980 Windforce 4GB (Overclocked to Boost Clock 1550 Mhz; Driver 376.33)
                      Render time: 15:30
                      • #89
                        Gainward GTX 1080 Phoenix GLH
                        FSR: v1.0.2
                        Drivers: 375.63
                        Time: 9min23s
                        • #90
                          FSR: v1.0.2
                          Drivers: 375.63
                          Time: 9min23s
                          Congratz for your new GTX!
                          Did you OC it for the test or you let it run at normal clocks?
