Oguz Birgoren's Fstorm Shortcuts Script. (FSS)
  • #16
    So, I installed this your script from MZP file, made a button on my toolbar. When I click this button and launching your script Error message window appears!
    https://fstormrender.com/forum/filedata/fetch?id=8593
    The same error which posted Selim Alp Yumlu before... I don't know why...
    3ds max 2016 + SP4, current render is FStorm.
    • #17
      it could be due to material library I provided not compatible with yours. Or you opened the material library is pre-2016. I dont know..
      Or Maybe it's due to current renderer is set to active shade rather then production rendering note.
      I believe if you clear your max settings it should work. Not saying that you clear the ini settings but. most of the people and I use the script everyday.
      When the script runs it looks for the current renderer first. if not it asks to change the renderer.
      next is the material library.
      it should be one the problem
      • #18
        How can I download the script?
