Fstorm Tools and Scripts
  • Fstorm Tools and Scripts
    Hi to all Fstorm users
    I opened this thread to share tools and scripts for Fstorm.
    This is first release of Batch load and convert to Fstorm requested here:
    http://www.fstormrender.ru/forum/for...=2880#post2880
    Tested on 3dsmax 2016
    Install**
    Unzip
    Drag and drop Mzp to your viewport.
    go to customize -> VFXCUBE category
    Share your Ideas and report bugs here.
    Thank's
    Ali Kavyani
      Getting an error message: MAXScript Rollout Handler Exception -- Unable to convert: undefined to type: Integer
        same here, get the same eror, using max 2015
          Works fine in max 2016,2017
          Investigating bug in max 2015.
          Cheers
          Ali kavyani
          • RobSteady
            RobSteady commented
            Thanks.
            I'm on Max 2014
          Fixed
          download from first post.
          Let me know if it works for you
            Thanks
            amazing script but i get error bitmap message when start batch convert
              Before converting scene be sure that all of your bitmaps are in OK status in asset tracking.
              This problem appear in all of converters when you have other status like found.
              • Anton
                Anton commented
                Thanks another question are you ali kavyani advanced user of redshift
                And if you are can you written a toolbar for fstorm with buttons like run Rt and fstorm cam from view?
                Can help a lot
                Thanks
              Yes,
              Written and finished
              will release in end of week.
                Reset material library to Fstorm requested in this thread:
                http://www.fstormrender.ru/forum/for...storm-material
                Find MCR in VFXCUBE category
                  Hi this is first release of my personal toolbar.
                  hope you find it useful.
                  **Install
                  Drag and drop mzp to your viewport
                  Find scripts in Fstorm tools category
                  More info in setup.
                    **Install
                    More info in setup.
                    Wow
                    Thanks so much.
                    Cant belive others arent chiming on this.
                      Thanks, works perfect now!
                      When Karba refines the conversion process, so we can get an exact translation...Game Over!
                      Is it possible to add a button for making favorite folders? Or set a default folder?
                      And right now it says "Fstorm" in the filenames - can you adjust it to "FStorm"?
                        Hi Rob,
                        Will adding this feature in new version.
