basically fstorm is saying am using less memory than msi after burner and also its saying i have only 6.85GB in fstorm, i am using a 1080 so not sure what's going on there and why its showing less memory than i have. see the image for comparison
Fstorm memory different from msi memory usage
Hello mitviz.
This time I am illuminating you
8GB - 6,85GB = 1,25GB -> this amount is being used only for opening Max and other software.
So, 3,76 + 1,25 = 5,01GB -> which is the amount indicated by MSI.
FStorm indicates the memory exclusively used for itself (without counting the VRAM used by other, like your 1,25GB "lost"), and the memory free which could be used. Try, for example, to conect your HDMI to your motherboard instead of your 1080 and you will see that the amount of free memory is increased up to 7 or 7,5GB maybe.EVGA GTX 1060 SC 6GB GDDR5 @ 2151MHz || i7 3770 @ 3,7GHz || G.Skill Ripjaws X 16GB @ 1600mhz
thanks for this! i was thinking it was that but at the moment nothing is connected to the 1080, those are connected to the 970 i have
Oh, yes, I was a little wrong with my stimation, but alsmost the same. I usually have 4,9GB free of 6, so I lose 1,1GB. You lost 1,25GB. It simply depends of the softwares you have opened, etc. If you want to have a little more free, close 3DS Max and open it again. And for a little more, restart the PC. With a refresh start I have seen 5,5GB free. So you are in normal values, don't worry.
