i would like to know if this is in fstorm, i want to later buy altus but i am checking if all is there
Altus denoiser
Originally posted by mitviz View Post
it stil wont maybe be as good as altus if they do make one, altus does on this so they are way more advanced than the denoiser in vray and corona
GPU support in Altus sounds intereresting thoughLast edited by RobSteady; 12-17-2016, 05:53 PM.FStorm 1.3.0d I Max 2018 I Win7 I i7 5930k I 64GB I 3 x 1080Ti
- 1 like
give altus a test and compare it to the corona denoiser you will see the difference
These examples here are very convincing to me:
http://www.recentspaces.com/blog/201...ng-comparisons
Rendering out two different beauty passes + multiple info channels and then use another software to calculate a denoised image seems also like a long-wided process.
Single click solution from Corona is much more convenient.
these tests done with corona that i did was awhile now, and this one you posted is basically nothing, i can same result in photoshop, with alot more noise altus and give the same image, when corona can do this let me know https://www.innobright.com/
All Denoisers from Altus to V-Ray to Corona work in a similar way and use information from info channels (normals, albedo...) to calculate noise levels and preserve details (well, kind of) this way.
All other denoising solutions (Nik DFine, RE:Vision, Neat Image, Photoshop, Noise Ninja) are strictly 2d processes.
The nice thing about V-Ray and Corona is that you don't need to buy extra software because they are integrated. At least for Corona I can say the process is dead easy.
With Altus you need to save two different beauty passes plus five render channels for each.Last edited by RobSteady; 12-17-2016, 09:42 PM.FStorm 1.3.0d I Max 2018 I Win7 I i7 5930k I 64GB I 3 x 1080Ti
Originally posted by RobSteady View PostAll Denoisers from Altus to V-Ray to Corona work in a similar way and use information from info channels (normals, albedo...) to calculate noise levels and preserve details (well, kind of) this way.
All other denoising solutions (Nik DFine, RE:Vision, Neat Image, Noise Ninja) are strictly 2d processes.
now, the noise type matters too (for RE:Vision), for example my Vray do not have noise reduction, and I need a lot more of clearance in VR output to be able to get a smooth flicking free result keeping the same amount of details in comparison with Fstorm
I would still appreciate an integrated solution to get rid of the last amount of noise that is very hard to clean up in a decent amount of time (even on a high end quad 1080 setup). The crucial point are interiors with white walls.
And I'm talking about 5k final res images which is standard for us.Last edited by RobSteady; 12-17-2016, 09:58 PM.FStorm 1.3.0d I Max 2018 I Win7 I i7 5930k I 64GB I 3 x 1080Ti
Based on the test I made at collegues studio.. Altus needs massive amount of memory. So I tried to use it for large render outputs like 8K or 10K renders.
32gb system memory wasnt enough. and I couldnt test with gpu because it crashed i think because of vram not enough error.. for small resolution images it's very fast with gpu
Originally posted by oguzbir View PostBased on the test I made at collegues studio.. Altus needs massive amount of memory. So I tried to use it for large render outputs like 8K or 10K renders.
Sure, you probably will loose some details here and there - but just to have an optional backup to get rid of noise that is difficult to clean up would be great.FStorm 1.3.0d I Max 2018 I Win7 I i7 5930k I 64GB I 3 x 1080Ti
