Hi Andrey,
I use State Sets a lot but when I start to render through State Sets the render window freezes and only updates randomly, I also often cannot click the cancel button because it is at times located behind the render window. Because I cannot move the render window I cannot stop the render and have to wait until rendering is finished or I have to force quit max. Far from ideal. Could you fix this?
Thanks.
State sets rendering freeze
I tried it but it does not help unfortunately. Setting the assistant device to the monitor GPU does not help.
It is FStorm settings / GPU manager panelOriginally posted by Tok Tok View PostSorry not sure what you mean with "low priotiry monitor GPU", do you mean in the task manager?
With Corona I do not have this problem FYI. But maybe it is GPU related, I don't use any other GPU renderer.
Hi. I am not sure it is FStorm related, probably 3ds max in general. Try to set low priority for monitor GPU.
