Daylight system not working
  • Daylight system not working
    Hi, I've had some problems with the sun/daylight system. It seems to work fine with versions 0.2.2e but the later versions won't render. I'm using NVidia driver 369.26
    This is the log:
    An error has occurred on device Quadro M6000
    unspecified launch failure < copyDtoH < mCuInitPixelsData < renderSceneSamples < renderScene <
    Device Quadro M6000 must be restarted
    unspecified launch failure < cuCtxCreate < initContext <
    Device Quadro M6000 cannot be initialized properly.
    unspecified launch failure < mCuImageRawBuffer < renderSceneSamples < renderScene <
    Using a hdri in the environment seems to be fine it's just when I change to the sunlight/sky. I've tried on different scenes I've been working on and also an empty scene with just a box and sunlight and still seems to fail. Any help would be great, I can revert back to 0.2.2e in the mean time.
    Thanks
    Mike
    Hi, Update GPU drivers first
    Next update FStorm
      Still no joy after updating the drivers and then reinstalling the new 2.6a version.
        I remember Karba saying theres issues running fstorm on Quadro Cards. I know its not much help.
          Could you try this version?
          www.fstormrender.ru/Downloads/FStorm3dsmaxSetup_0_2_6d.zip
            Hi Karba, version 0.2.6d works fine with the Sun system now.
            Thanks!!
