Hey guys, just reporting two repeatable bugs:
1) FStormGradient - If you click on one of the color tabs. Pick a color or just close your color picker. Then double click on it again, max crashes. Even in an empty scene.
2) FStormProxy - If you merge an FStorm Proxy in from a scene that is in a different unit system (root, not display) than yours, it comes in at the wrong scale. For example if you have a scene in cm and you merge in a 1m x 1m x 1m box from a scene that is in mm or inches, it still comes in at the right scale. If you make that box into an FStormProxy and then merge it in, it comes in at the wrong scale. This can be verified by making a box in a scene with one unit system, copying it and converting it into a proxy, and then merging both the original box and the proxy box into a scene with different units. The box will be the right scale, the proxy will not.
