render elements maxscript
  • render elements maxscript
    hi all
    not sure it's a bug, however can't figure out how to add renderelements via maxscript, old codes not working as you can see (i added also a vrayelement just to test the old one works)
    HTML Code:
    renderscenedialog.close()
    re = maxOps.GetCurRenderElementMgr()
    re.removeallrenderelements()
    re.addrenderelement (FStormMaterials elementname:"notworking")
    re.addrenderelement (vraywirecolor elementname:"working")
    re.SetDisplayElements true
    renderscenedialog.open()
    as of now i worked around it by saving an indexed preset and rename the element output after loading but should be fixed i think.
    thanks
    -cdb
    Hi. I will check
      Hi. I will check
      Fixed, wait for a new release
        thank you!
