Hello Karba. Great job on render so far. I'm wondering if its not too much time to try to add MultiTexture map like the one used with FloorGenerator.
Here is the link https://cg-source.com/multitexture.php
And here is what they say about it
MultiTexture Map
MultiTexture Map is a plugin for 3dsmax that loads multiple textures and assigns them randomly, either by object or by material ID. With controls to randomly adjust the gamma, hue and saturation.
Version 2.01 works with 3ds Max from 2012 up to the current 2017 release. It's compatible with scanline, Vray, Brazil and FinalRender. MentalRay is currently not supported.
-Randomly loads textures
-Easy color adjustment
-Random color adjustment
-Works with FloorGenerator
I think its quite simple for someone who can do this.
I'm not sure if there is some easy way of doing this in Fstorm and also conversion from it doesnt work.
Hope you consider it. It would make at least my world a whole lot easier.
Now I'm not sure if this is the right place to ask for it maybe its their site but still no harm done.
Thank you in advance.
MultiTexture Map
