Interactive rendering add forest pro
  • Interactive rendering add forest pro
    I'd like to see forest pro updating in IR. At the moment if forest pro is set to camera, if I change cameras during IR forest pro doesn't update. It does in the viewport just not in IR.
    cheers
    you have to press update geometry button every time.
      Yeah thats the problem, anyway to change that behaviour ? I hate saying it, but other GPU renderers do it
        I know. I just have too much things to do now. I will implement it properly in the future.
          it's dangerous to update in realtime Forest pack Pro stuff...too much instances that turn on-off while the camera is moving... The manual update works great
            Completely agree !
              You can always turn on manual control on Forest pro, so we can have the best of both worlds.
                I am OK to press the update button from time to time.
                Btw, my forest pack material doesn't render in FStorm. It only renders default blank material. even when I scatter an object that I just created with all fstorm mat and fstormbitmap, as long as it's in the forest pack, the material doesn't work. Is that a bug or a feature to come or I am doing it wrong?
                Thanks!
                  Thanks!
                  I don't think Fstorm supports any other materials besides Fstorm.
                    FStorm doesn't provide full support of Forest Pack. At some point I will implement FStorm Scatter.
                      So does fstorm support forest part material and map ?
                      http://docs.itoosoft.com/display/FORESTPACK/Material
                      http://docs.itoosoft.com/display/FOR...orest+Material
                        FStorm provide full support of Forest Pack. At some point I will implement FStorm Scatter.
                        My issue is, my forest pack object only shows default grayish material, no matter whether I use FStorm mat + map, or the material that comes with forest pack library.
                          Sorry, I wrote my sentence incorrectly. was too tiered.
                          FStorm doesn't support forest pack materials. You have to assign fstorm materials to forest pack objects.
