otoy team philosophy: picking on the little guy
That only feeds my disappointment towards this "i-have-big-plans" company. Their product has become worse over time, instead of improving. Slower, unstable, memory-inefficient, nearly unusable for professional work: it has become a mess without a concept. Users go for things that actually work.
That said, they are ending up suing one of the persons that mostly contributed in making their product better during the golden times, which may be legit, but from an ethical point of view they should also thank him.
M.
Originally posted by wastzzz View PostThat only feeds my disappointment towards this "i-have-big-plans" company. Their product has become worse over time, instead of improving. Slower, unstable, memory-inefficient, nearly unusable for professional work: it has become a mess without a concept. Users go for things that actually work.
M.
Hope everything turns out well for FStorm.FStorm 1.3.0d I Max 2018 I Win7 I i7 5930k I 64GB I 3 x 1080Ti
If not using any code then it's fine, but doesn't stop getting picked on to try exhaust resources of the small fella.
Wonder why the high court of NZ, Karba's not in NZ right.
Anyway looking forward to an update, if need some community donations to get moving again reach out Karba.
Not impressed with OTOY, self righteous idiots, they are making a bad name for themselves quickly in the rendering space.
I hope so Karba (that the Court is fair and reasonable based on the facts), I'm from NZ so I'm hoping to purchase!
I thought you were possibly in NZ, now makes sense why they go NZ first then, as if they get across the line here then they go elsewhere/countries.
Happened for many political and judicial systems in the past, several come to mind, including Kim Dotcom.
They are only using NZ as a test case to get the ball rolling, you need to stop it here.
NZ has likely one of the smallest % global uptake/purchase of any renderer, anywhere on the planet, makes you think...Last edited by adams; 07-31-2016, 08:53 PM.
Originally posted by adams View PostThey are only using NZ as a test case to get the ball rolling, you need to stop it here.
Your "answer" has to be bulletproof otherwise this will go on a long time and cost you a lot of energy/time. They will probably even argue that you're using similar desciptions like importance sampling, kernel settings - the cheap way.
Wishing you good luck!FStorm 1.3.0d I Max 2018 I Win7 I i7 5930k I 64GB I 3 x 1080Ti
