FStormRender for 3ds Max v0.3.8a, Hot fix.
  • Karba
    started a topic FStormRender for 3ds Max v0.3.8a, Hot fix.
    Bug fixes:
    black textures in 3ds max viewport
    invisible light blocks direct lighting
    This build requires 3ds Max version 2014 - 2017, GPU with CUDA support and compute model 2.0 or higher. https://developer.nvidia.com/cuda-gpus
    FStormRender for 3ds Max v0.3.8a(13Mb)
    This is the last free version.
    Next versions will be commercial.
  • adams
    replied
    I'm getting issues with material shader ball (black)on latest 376.19 driver - anyone else having issues? Suggestions for fix, I know there have been problems in the past with black shader balls, I'm sure were driver related
  • Sylk
    commented on 's reply
    At least it fix this bug http://www.fstormrender.ru/forum/for...=6773#post6773
    Next you can make some tests to check the better for your works.
  • Iskánder ivp87
    ha! downloading again then... thank you
    any clue what the differences could be? or if this last update is at least as good as the 3.7a?
  • Sylk
    Yeah, the last update was uploaded on 9/11
  • Iskánder ivp87
    replied
    Hi, I downloaded the 0.3.8a the 8th of this month, I installed it but ended going back to the 0.3.7a since it gives me faster results and in a consistent way, and the difference in render quality is almost not noticeable if there's any at all
    since then (8/11/2016) have this version been updated?
    thank you
  • Sylk
    replied
    You probably downloaded 0.3.8a long time ago. I have reuploaded 0.3.8a 2 times.
    Right, anyway 0.3.8 v3 only solve v2 issue but not the v1 issue...
    Edit: "0.3.8 without issue" looks to just be lucky during tests. 99% of time Max not closing properly. Previous test confirming the issue is caused by VRay seems to be true.
  • Karba
    replied
    Originally posted by Sylk View Post
    For the first time since i test Fstorm, with this 0.3.8a v2 the console stay always visible and it keeps Max open after closing main max windows!! (see pix)... Not occurs with the 0.3.8a v1.
    Please hide it like previous versions. Or reupload 0.3.8a v1.
    HOWEVER, closing of this console correctly close Max process, WHILE the 0.3.8a v1 keeps Max process in background!
    In both cases FStorm prevents proper Max closure.
    The 0.3.8 version doesn't occur any of these issues.
  • Sylk
    replied
    Looks like driver check doesn't work sometimes. I have removed it. Please redownload it again.
  • Sylk
    I agree with that
  • gvman
    replied
    1) Just water marks. No other limitations
    2) In 1-2 weeks, I hope.
    3) First commercial version will not have many new features, mostly bug fixes.
    Absolutely love to hear that. Thank you for the screenshot. It's a very gentle watermark, to be honest it's the best I've ever see so far. And I'm glad to see, you did a lot of user's attention.
  • m17a4y
    replied
    Please, can you just release the hot fix, without the new features, before the commercial version?
    That would be awesome if it happens!
  • Sylk
    replied
  • Karba
    replied
    Originally posted by gvman View Post
    Any further info?
    1. There will be other restrictions? Time, resolution, anything else? Please don't be crazy agressive like Octane, which can be very disappointing.
    2. When can we expect the first commercial version?
    3. Whats coming next? Are there any plans?
  • gvman
    replied
    Demo version with watermarks will be available.
    Any further info?
