Is the new color management system going to affect how accurately fstorm can render colors? Right now for example when you render a black object there is a jump from RGB 21,21,21 to RGB 28,28,28 (if I'm correct in these values) so there is nothing in between. This has always been a problem for other renderers too since max only supports 8bit colors as I understand it. In quite a lot of cases there is a big jump in colors in the renderer and is actually a bit weird that this has not been addressed from autodesk. Now with the new color management system, is this a thing of the past or does it not work in this way?
