Light texture projection
  • Light texture projection
    Hi! How do i get the texture projected through the light?
    I mean how to get sharp clear shape of it? If i put a texture to the light what i get is blurry/soft image instead of the clean picture even with the directional amount of 1. Also it`s pretty noisy and need a lot of iterations to clean. Here is a quick example. If i use simple 3d max direct light with texture, i get very sharp 100% same result as a texture. But i can`t get the same in fstorm. How to do it?
    Hi
    1) You have to use bitmap texture in perspective environment mode.
    2) Light source has to be very small with high power.
      It worked. Спасибо за помощь!
