Hello, I've got some difficulties to set up scattering materials for thin objects (not surface but less than 1 cm). I start with mats from the demo scene screwdrivers. I believe that the handle are a bit oversized (radius 7cm - length 50 cm).
Using this materials I can not achieve to get a nice SSS by only playing with Scattering color value/density, I have to set refraction glossiness very low (0,001 to give an idea). Is it the right way to do it ?
I can do something also by lowering distance in volume setting. Maybe the best approach.
I have difficulties to create a thin (3 mm) white acrylic glossy mat.
https://image.architonic.com/img_pfm...te-cube-sq.jpg
Thank you,
Christophe
Thank you,
Christophe
