Those features are very Advanced & important // is really impressive your development speed & passion. We Support You!
RoadMap Feedback
Originally posted by kahein View PostI am amazed by the speed of your reactivity +build and bug fix)
And by the estimation for integrate new features. It seems too simple for you.
Great work. Keep it as simple as possible.
That would be hard to organize. And I don't think it is necessary.
Originally posted by voltaire585 View PostKeen to see normal maps. and the interaction and realtime update function could do with some work eg like another renderer we know. Amazed at the speed of development. Nice work.
Hi
The problem is fstorm uses height based metric bump. It is not easy to add normal map bump.
Regarding realtime update - it is always in my mind. I will implement it when I find some good and stable solution.
I'm pretty sure you're working hard to implement more robust and realtime updates.
As far as I'm concerned I do love to see the changes I make immediately on the RT window... Not complaining or anything. When you do that I'll make the change to Fstorm right away.
if would help lower any render details on the first go. Make the post Glare unchecked or do anything needed to make this brilliant renderer RT window update/refresh faster than ever. That is the utterly most important feature for me....
Thanks for all the hard work. My money is ready)
Originally posted by oguzbir View PostI'm pretty sure you're working hard to implement more robust and realtime updates.
Render is not a game engine where high fps is required.
Even if you get a picture with one sample immediately it is an entire noise without any details.
I've been testing and looking at GPU renders for years since Iray peaked its head out but could never pull the trigger on purchasing because of non convincing render speeds. The other day I was doing my own bench mark interior/ exterior scratching my head wandering why they wouldn't implement a feature that focuses the GPU power on noisy areas as opposed to the whole image... Then the same week I used Fstorm!!! super stable and by far (hours) the best render times.. Oh did I mention proxies. Thanks Dron for making my computer build worth while. Let us know if there is anything specific you'd like us to test. IE is there a spot on forum where we should be going for direction in helping you develop Fstorm further? Even though its already a beast and I would purchase this 100%
To stay on topic, This is a big leap, but do you plan on doing a Maya version once Fstorm for max is up and running?Last edited by SameHere; 07-13-2016, 02:18 AM.
Originally posted by SameHere View PostI've been testing and looking at GPU renders for years since Iray peaked its head out but could never pull the trigger on purchasing because of non convincing render speeds. The other day I was doing my own bench mark interior/ exterior scratching my head wandering why they wouldn't implement a feature that focuses the GPU power on noisy areas as opposed to the whole image... Then the same week I used Fstorm!!! super stable and by far (hours) the best render times.. Oh did I mention proxies. Thanks Dron for making my computer build worth while. Let us know if there is anything specific you'd like us to test. IE is there a spot on forum where we should be going for direction in helping you develop Fstorm further? Even though its already a beast and I would purchase this 100%
Hi. Thank you!
Nothing specific. Just do testing, features requesting and bug reporting
- 1 like
