FStormRender for 3ds Max v1.5.1d
  • FStormRender for 3ds Max v1.5.1d
    • 3ds max 2023 support
    • removed 3ds max 2014-2015 support
    • FStormScatter
    • FStormScatter shape area controll
    • FStormScatter preview object number controll
    • FStorm Output texture suuport clamp option
    • custom material for gray material rendering
    • FStormCamera viewport FOV limit
    • inconsistent FStormFur and FStormScatter geometry generation
    • FStormScatter crash with network rendering
    This build requires 3ds Max version 2016 - 2023, GPU with CUDA support and compute model 2.0 or higher. https://developer.nvidia.com/cuda-gpus
    Hi Andey,
    I'm a little sad of the removel of 2015 being that I'm still using this version to finish a film that I've been working on for six year. I undestand asking to keep support for it is difficult, but if that's not doable will I still be able to use Fstorm on this version with v1.5?
      How come you dont upgrade ?
        Because of about 500+ VFX shots that I am personally making on my own (long journey) I hope to finish my film's VFX this year, after that I'm planning on upgrading. Also, I'm still on Win7 still and tried upgrading slowly in the past but had some bad results so I decided to stay as is until I reach the deadline. What's been a challenge sometimes is on paid gigs from clients and not having some features, but most of the plugins I have fill the void of what lacks in newer versions of MAX. Ironicly I might have a new gig that will be enough to build another new setup for render and work, (but still think it's best to finalize the film in it's current setup.)
          Good luck ! ..
            Version is updated to 1.5.1a
            • FStormScatter
            This update is about FStormScatter implementation.
            This is a test build, it may have some bugs.
            Don't use FStormScatter in major commercial projects.
            FStormScatter can be found in 3ds max geometry objects in FStorm category near FStormProxy object.
            Here is a simple FStormScatter demo scene
            https://fstormrender.com/wa-data/publ...leDemo2018.max
              Fantastic, testing tonight and will give my feedback ....YES !
                Its great ... all that's needed is Collision parameters ... Great work guys
                  My apologies, right click !
                    Ok so i cant get Collision to work .. any tips Karba
                      WOW ! very very impressed, this is so powerful and not faltered once ... just keep adding whilst in RT mode ..instant results ! and memory usage fantastic ... time to play
                        Question, how do you make a Collision Group ? cant find it
                          Scatter doesn't seem to work with Displacement
                            Can you use Multi texture ?
                            • #15
                              Great job Andrey !
                              if I can suggest.
                              - Adding a on/off checkbox on the scatter node and on each node available or a lookthroug or bypass statut.
                              - adding the possibility to paint over the surface directly like the Soulburnscript objet painter (http://www.neilblevins.com/art_asset...for_3dsmax.htm)
                              - add a little help or description of the node
                              - possibility to copy/paste the selected node or shift or ctrl or alt drag it to duplicate it
                              - adding a merge node to merge multiple object node to branch in one after if the list is not possible
                              - dont know if its possible, the possibility to select multiple nodes and have them in the right panel like nuke or fusion with a possibility to show a limit of 1 to x node in the right panel
                              - add a statut bar to see when fscatter is cooking the node.
                              - possibility to select from object/surface node the source used in the node
                              - possibility to show in the viewport the generator node selected in overlay
                              - possibility in the generator to choose the count preview of display as box mesh
                              - maybe add a scatter list like light lister
                              - test with heavy three in proxy, 1000 instance, the rt is really fast, it update instantly when i put a value but, i have a delay for the scatter editor to be usable and the viewport.
                              - some crash happen with black viewport try to refresh the cooking
